Specs#
Description | SLZB-06 | SLZB-06M | SLZB-06p7 | SLZB-06p10 |
Release Year | 2022 | 2023 | 2024 | 2024 |
Zigbee SoC | СС2652Р | EFR32MG21 | CC2652P7 | CC2674P10 |
Core SoC | ESP32 | ESP32 | ESP32 | ESP32 |
Matter Support | Yes | Yes | Yes | Yes |
Ethernet | Yes | Yes | Yes | Yes |
PoE | Yes | Yes | Yes | Yes |
Support Open Firmware | Yes | Yes | Yes | Yes |
Support ESPHome Firmware | Yes | Yes | Yes | Yes |
Where to buy them?#
Optional
- POE injector 48v 24w
- Amazon: (POE injector 48v 24w)
- Aliexpress: (POE injector 48v 24w)
Documentation#
Default URL#
- Wifi Mode URL: http://192.168.1.1
ZHA Integration#
How to add Zigbee Devices with ZHA#
You can use this button to be redirected to you Home Assistant instance to add the device to your Zigbee network.
Zigbee2MQTT Add-on#
Note: This is an alternative to the ZHA integration. You can't use both at the same time.
Settings > Add-ons > Zigbee2MQTT > Configuration > Serial
port: tcp://slzb-06.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06m.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06p7.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06p10.local:6638
baudrate: 115200
adapter: zstack
